Incomplete file reference information
Vault 2022, server build 27.0.80.10, client built 27.0.80.0. Inventor 2022.2.
When attempting to move large amounts of Inventor files in Vault, I came across the following warning for about one in every thousand or so:
I believe that proceeding with YES would cause some related assemblies/drawings that consume such files to become unresolved, is that correct?
I could only find an Autodesk article on this type of issue in Google cache, not active anymore:
However, the fix's suggestion of using "Update File Reference" did not solve the problem, as the warning re-appeared when attempting to move files again. Is it necessary to open the individual files, save them again in Inventor, and check them back in to fix this (migrate that way if needed)? Would there be any way to search for whichever files have this issue before attempting to move them??
Thanks for any tips/hints in the right direction.
