We are in the midst of upgrading from Vault Server 2022 to 2025 on our VM.
It should run off of SQL Server 2017 but is giving me the error attached: An incompatible database version was detected that cannot be migrated. I have checked out the following article but the causes are not relevant.
Could our version of SQL Server 2017 (RTM-CU31-GDR) 14.0.3480.1 be missing updates or fixes that would make it incompatible with vault 2025 server? Would installing a later version of SQL Server fix the problem? I assume that I would not have to remove the MSSQL14.AUTODESKVAULT database instance?
