I have company “A” with Vault Prof.
Company “B” will look at the files from Conmany “A”.
Company “B” will use the Thin Client, this consumes no license. I’m not sure this ist allowed.
thanks Juergen
Solved by Elisabeth_Boehm. Go to Solution.
Hallo Jürgen,
1.
when the Company "B" will logging in with "read Only Access" then the User need no license.
2.
when the Company "B" will logging in and will use a license, then check, that the Company "A" has installed the Autodesk Office 2017 (server) on the Autodesk Vault Server.
Best Regards,
Elisabeth Böhm
