@Anonymous wrote:
1. What are all factors do I need to consider to decide where I need to install Vault File Server or not?
2. Is it possible to download all of Vault Professional software on my laptop and then upload it to the AWS EC2 instance in an isolated environment that does not have internet connectivity?
Question 1:
Vault File Server is used as part of a replicated Vault Server environment.
Do you plan to have your users access the Vaulted-data from several different geographic locations? Think users in the EU and in the USA working on the same Vault environment.
If so, you can set up the Vault system to have a master Vault Pro Server install on one continent and either a full replicated site with both a file store and the SQL databases or just the CAD files on another.
If you use mirror both the CAD files and the SQL databases, you are using full replication. In this case, the users in the EU will access the Vault Pro server installed on a EU-based machine and the USA users will access the Vault Pro server installed on a USA-based machine. Proper setup of the replication environment will keep both the file store and the databases in sync.
Vault File server is used when you only want to replicate the actual design files between sites. It does not replicate the SQL databases. In this case, users will have to access both the main Vault Pro Server and the closest Vault File Server install.
See the Vault File Server help files: https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Vault-Admin/files/GUID-57B5FA00-BC95-4A45-BB58-873862EE4A8C-htm.html
And the Full Replication help files: https://help.autodesk.com/view/VAULT/2020/ENU/?guid=GUID-D8678874-4839-41AD-BD58-226AF3862D3D
Question 2: See the Vault Help files here: https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Using-Vault-with-the-cloud.html
These are advanced ways to set up Vault and you may benefit by working with a specialist Vault consultant.
Steve Walton
Inventor 2025
Vault Professional 2025
