How to Enable Vault thin client to view PDF files in a seperate tab instead of using the Forge Viewer
Aadithya01
Advisor Advisor
Aadithya01
Hi Guys,
When we click the view option in Vault Thin Client to view a PDF file. The PDF should open as a seperate tab within the browser. Instead now it uses the Vault Forge Viewer within Thin Client to view the file.
Is there a setting where we can set to View only the PDF files as a seperate tab rather than viewing it in Vault Thin Client Viewer ?
Kindly looking foward for some reply.
rtowne72
Check your system's default handler for PDF files.  I have Acrobat set as the default handler, and when I do as you show, my thin client opens in a new tab as you are requesting.  I was also able to verify when clicking the check box and choosing the eye icon to view the file.  Alternately, when I use the View tab, it does use the Viewer.  We are also on Vault 2024 and the latest update; you might want to look into that if you are not on the latest update.
Rob Towne
Sr. Engineer/CAD Manager | A.L.P.
Inventor/Vault Professional/AutoCAD
ihayesjr
Also, if you are in the view tab, use the Open in Browser button.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Aadithya01
Hi @ihayesjr ,
We tried the option you had mentioned as well. But still it opens the PDF in a new tab in the Forge Viewer, not in the default PDF browser viewer (but previously the PDF files viewed only in browser tab and not in Forge Viewer).
ihayesjr
@Aadithya01
What version of Vault are you using?
Also, can you provide a video show the workflow and the results?
Irvin Hayes Jr
Autodesk, Inc.
