Folder properties populating to file properties
Alriddin
Alriddin
Does anyone have a good idea of what is required to input a property at a folder level, and have this property automatically assigned to all sub-folders and files?
For instance, using Data Standard to specify a project number for a folder. And all the sub-folders and subsequent files will inherit this property, minimizing the need to input this property value per file.
ihayesjr
Sorry, but there is not a way to propagate folder property values down to subfolders.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
-Roland-
CGBenner
@Alriddin  Did the information provided by @-Roland-  answer your question? If so, would you please use Accept Solution so that others may find this in the future? Thank you very much!
Chris Benner
