Announcements
File is not in the search path
NachitoMax
NachitoMax
Hey
just set up my new vault, followed TFI-CAD setup. I have a question:
In my Vault Explorer$, i have a sub folder called Special Projects that we dont want to have in the same level as our standard projects. Our Standard projects folder is named just that. This is the folder that is set to a workpath in the project ipj.
when i open a file in special Projects, i get the error 'File is not in the search path' but its in the same level as the ipj. does this mean i will need to move it 1 level down into Engineering Data in order to edit it without project issues?
thanks
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Gabriel_Watson
Watch from 15:20 to 19:20. Short answer is yes, you will need any files to be within the working folder set by your project and Vault:
https://youtu.be/eFGON1CIhns?t=920
