Exporting My Search Folders
miechh
miechh
In a few weeks we will install Product Suite 2014 in our company, and with this an install of Vault 2014 will be done. In my Vault I created a lot of search folders which help me daily with reusing content. My experience with installing a new Vault version is that I lose the search folders I created.
Is there a way to export the search folders I created, so that I can import them in the new Vault version?
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 10 Professional (64bit)
miechh
Still no answer on this. This month Inventor 2015 will be released, and probably with that comes Vault 2015. This means all my Search Folders in Vault 2014 will be gone, and I have to manually 're-design' them all, again.... I'll give Kudos to those coming with a solution.
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
ryan
Your searches can be copied.   The exact path depends on 3 things; your username, vault version and vault name.
In my case, the searches are stored on my workstation at C:\Users\rsmall\AppData\Roaming\Autodesk\VaultCommon\Servers\Services_Security_1_28_2013\localhost\Vaults\VaultDemo\Searches
Ryan Small
National Team Leader, Data Management and Software Development
SolidCAD, a Cansel Company (an Autodesk Platinum Partner)
www.solidcad.ca
scottmoyse
Doug Redmonds Project Thunderdome Vault Extension did a wonderful job of extracting this lot. If it did nothing else, it showed you where all these settings are stored. I don't believe it has been updated to 2015 yet.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
scottmoyse
I'm just wondering if you searched this forum for the answer?
This post contains information about the location of the saved searches for example.
This folder contains some settings you can transfer:
C:\Users\XXXX\AppData\Roaming\Autodesk\XXXVault EditionXXX\
Scott Moyse
miechh
Okay, thanks! This solves it for now. Still I think there should be an export-function in Vault to backup saved searches!
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
