Announcements
Error saving sheets from Revit 2025.3 to Vault 2025.2
anazarov3SDTA
Message 1 of 1
anazarov3SDTA
Hello, everyone!
I'm testing a model created in Revit 2025.3 for compatible work.
I placed the central file on the local machine in a separate folder.
Further, for the package in the Volt Professional 2025.2 repository, in the settings, I specified the path to the local folder where the central file is located.
Then I created a new local file from the central file.
I developed a model in a local file and created sheets. After that, he synchronised the model with the repository.
Next, I created a binder and selected the sheets to be saved to the repository.
Then click ‘Ok’. And I get the error ‘There are no sheets to add to the repository’.
A folder with sheets is created in the storage itself with a subfolder called Sheets, but there are no sheets inside the Sheets folder. There is also no saved binder file.
Could you please tell me how to fix this error?
Replies (0)
