Hi Sirs,
I have found this issue when copy design. Parents, sons and neighbours files run well as alone copy.
Attached you can find an image and log lines in server...
06/05/2011 11:45:39 *******************************************************************
Error: Soap Exception ( mesg-id = 634402791399426250 )
Exception: GetFileFailed [1013]
Stacktrace:
Server stack trace:
en Connectivity.Document.BusinessLogic.FileBL.GetFilesByMasterId(Int64 masterId)
en Connectivity.Document.Services.FileService.GetFilesByMasterId(Int64 masterId)
en System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
en System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Exception rethrown at [0]:
en System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
en System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
en Connectivity.Web.Services.DocumentService.GetFilesByMasterId(Int64 fileMasterId)
Stacktrace:
Server stack trace:
Hi Mr. Smith,
Attached you can find the error dialog box when try to do a copy design.
In Inventor environtment, runs well.
I can rename the file.
I can move the file.
Its parents and its sons can be copied.
Regards
