Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
ERROR: CHECKING ASP STATUS
5 REPLIES 5
628 Views, 5 Replies
First of all I will give you a background on how I got this error message.
I finally got Vault Manager to install on the server runnning Windows Server 2003. As we bought a new server and made a fresh install. The install was successful without SP1. After installing Vault Manager, windows update wanted to run SP1. Then things started to go wrong. Clients could not log into the vault. Although logging into the Vault Manager was possible by the administrator. After talking to the reseller in trying different methods to try and fix it, it was to no avail, and we had to end up uninstalling Vault Manager and reinstalling it.
After reinstalling it, (now with SP1) the pre-installation checks give me a ASP error the actual error is "The request failed with HTTP status 404: Not Found" I followed the instructions in asking me to uninstall NET.Framework 1.1. But noticed I didn't have v1.1 but v2.0, so continued to uninstall it v2.0. Tried to re-intall, and the same error message is shown. Tried to uninstall SP1 retried an install and same error.
Now I've cleaned up the OS deleted all folders and registry entries associated with Vault. Installed SP1 and NET.Framework 2.0. Then did an install and same error.
Does anyone know how to finx this problem or bypass it?
5 REPLIES 5
Have you allowed ASP.NET in IIS? See the attached image...
John Huber
Autodesk RRT
wrote in message news:5148110@discussion.autodesk.com...
Thanks for your help John, all is going well. I never looked to check that. It seems as thought uninstalling the Vault Manager from the workstation reset the IIS - ASP.Net service on the server machine, and NOT from SP1 being installed.
kevincurrey
What should be done to fix this error if we are running IIS 5.0 (on windows xp)?
Check and see if there is any information in the Windows Event Log.
wrote in message news:5166403@discussion.autodesk.com...
xp)?
This error can be caused by the lack of permissions on the ASPNet Temporary
folder and errors in the COM+ service.
For the temporary folder permission see the following Microsoft
Knowledgebase article:
a.. 825791 - PRB: CS0013 or CS0016 Compilation Errors in ASP.NET Web
Applications.
http://support.microsoft.com/default.aspx?scid=kb;en-us;825791
b.. 322886 - Error When You Invoke Methods on a Web Service by Using ASP.
http://support.microsoft.com/default.aspx?scid=kb;en-us;322886
For errors with the COM+ service see the following Microsoft Knowledgebase
articles:
a.. 301919 - PRB: Cannot Expand "My Computer" in Component Services MMC
Snap-In. http://support.microsoft.com/kb/301919/EN-US/
b.. 891801 - How to reinstall Microsoft Distributed Transaction
Coordinator on a computer that is running Windows XP.
http://support.microsoft.com/kb/891801/en-us
c.. 873151 - You may receive an error message when you configure IIS
virtual roots in Windows XP Service Pack 2 or in Windows XP Tablet PC
Edition 2005. http://support.microsoft.com/kb/873151/en-us
Irvin
"Paul Gunn" wrote in message
news:5171557@discussion.autodesk.com...
xp)?
