I have as of this past weekend upgraded our Vault server and clients as well as our design software to their 2024 versions with all the latest updates. The job processor is not processing DWG files but in fact erroring them out. I will include what the log file states. All Inventor files are processing fine. No setting was changed to impact this so I am lost. I have scoured the web and forums and tried a plethora of try's and fixes but to no avail. I have also made sure Trueview is good to go and manually exported a DWF from it. Side note: The "local" update in Vault also fails.
Update: I stand corrected...Trueview is not manually exporting DWF or PDF files either. I have installed a fresh version of Trueview and no help. My guess is that it has something to do with it and not Vault itself. Still looking for help however.
General 11/7/2023 3:00:19 PM
Job 2717490 : Autodesk.Vault.DWF.Create.dwg
General 11/7/2023 3:00:25 PM
DWFGenerator.TrueViewDWFEngine.Initialize | 'Create TrueView Instance'
DWFGenerator.TrueViewDWFEngine.DWF | 'Cannot find the published file.'
DWFGenerator.TrueViewDWFEngine.Release | 'Release True View'
It looks like an error occurred during the file export. Please try again.
Autodesk.DataManagement.Client.Framework.Internal.ClientException: It looks like an error occurred during the file export. Please try again.
at Connectivity.Explorer.Document.ViewModel.UpdateView.CreateDwfImpl()
at Connectivity.Explorer.Document.ViewModel.UpdateView.CreateDwf(Boolean& isCancelled)
at Connectivity.Explorer.JobHandlerDwfPublish.DwfJobHandler.Execute(IJobProcessorServices context, IJob job)
DWF Create: test-delete.dwg | Failure
Completed executing
