DWFs created for an IDW on the computer show no text
mitchELAHB
Message 1 of 10
mitchELAHB
I've ran into a strange problem. When I create a visualisation file of an IDW using Vault on the computer, it doesn't display any text, however if I do it using the Vault mobile app on a iPad, the visualisation file looks fine. I have tried this on several computers and have come across the same problem. Visualisation files used to work fine, older IDWs have their text on them. There are several things I have implemented in Vault since I last remember visualisations working:
  • Enabled the job processor
  • Ran workspace sync
  • Added some required properties for files of a certain category (which includes IWDs)
  • Made changes to the Vault Data Standard
I had at first thought it would have been the job server causing issues, but the DWFs are set to be created on check-in on the local machine, and it does not matter whether I update them locally or on the job processor, the issues still persists. I have included a screenshot from both the computer and iPad. Note, this is only a problem for IDWs, PDFs display correctly. Does anyone know what could be causing my issue?
Replies (9)
Message 2 of 10
gandhey
Hello @mitchELAHB ,
What Vault version are you on ?
Is it possible to share the files - if yes please share the same on - [email protected]
regards,
Yogeshwar
(Vault team)
Message 3 of 10
mitchELAHB
Hi Yogeshwar.
We are running Vault Professional 2024. I have sent you the files 'Shelf 2.ipt', 'Shelf 2.idw' and 'Shelf 2.idw.dwf'. I have tested many files and I've had this problem with every one of them, so it's not file specific. If I open the dwf in Design Review it displays fine, it's only within Vault I get the problem.
Message 4 of 10
gandhey
Hello @mitchELAHB ,
I havent received the files / email.
Can you check once / resend ?
Yogeshwar
Message 5 of 10
mitchELAHB
I have resent the email, I hope you have received it.
Message 6 of 10
ihayesjr
@mitchELAHB
Have you checked the fonts being used in the drawing?
Download the DWF from the Vault Client and open it in Design Review to verify that the text is in the DWF.
You will have to turn on "Show Hidden Files" in the Vault Options.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 7 of 10
mitchELAHB
The DWF is fine if I view it through Design Review, it's only when I try viewing it in Vault that the text is missing.
Message 8 of 10
ihayesjr
What update of 2024 are you running?
Irvin Hayes Jr
Autodesk, Inc.
Message 9 of 10
mitchELAHB
We're running 2024.2 Build 29.2.88.0
Message 10 of 10
mitchELAHB
Hi
Yogeshwar, did you get the files? Did you have any luck recreating the issue ?
Irvin, any updates in regards to the build number?
I've noticed we have similar issues with DWGs as well.
