DWF vs. DWFX extensions
BCrosby
BCrosby
I have Vault Publish options set up to publish DWFX options but I still see DWF files being created. What am I missing? Is this not where the extension is controlled?
Bruce M. Crosby
Broomfield
Engineering Department
GIGABYTE Z490 Vision D (Intel LGA1200/Z490/ATX/3xM.2/Dual Thunderbolt 3/SATA 6Gb/s/USB 3.2 Gen 2/Intel WiFi 6/Direct 12 Phase Digital Power/Intel 2.5G LAN/Motherboard)
Intel Core i7-10700K
Samsung (MZ-V7E1T0BW) 970 EVO SSD 1TB - M.2 NVMePNY Quadro P5000 VCQP5000-PB 16GB
Crucial Ballistix 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 128GB 32GBx4
Dell Ultrasharp U4919DW Curved 32:9 49” Display
Windows 10 Professional 64 Bit
CAT 7 Ethernet
HP Designjet T3500
3D Connexion SpaceMouse Enterprise
3D Connexion CadMouse
Autodesk Vault Basic 2020
Autodesk Inventor Professional 2020
Autodesk AutoCAD Mechanical 2020
ihayesjr
Yes, this is the correct location for the setting.
When is the DWF file still being created?
Is it during file Check-in?
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
BCrosby
Yes, It is being created during check in.
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
ihayesjr
Has the user logged out and back into Vault after this setting was made?
Irvin Hayes Jr
Autodesk, Inc.
BCrosby
I doubt it. I will give that a shot.
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
BCrosby
After logging out of Vault and back in, the IAM and the IPT files get published as a DWF and the DWG gets published as a DWFX.
All of the applications in the visualization publish options are set up to a DWFX file type.
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
