- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm experiencing the same error on two different Vault Job Servers: the first is a brand new server with a fresh Vault DB created directly with 2023.1.1, the second is an already working Vault since 2012 and updated from time to time, recently updated to 2023.1.1.
In both cases, Job Processor is on a brand new, Windows 10 separate machine.
I'm unable to update DWFs via Job Processor; in addition, if I open Vault Client on the Job Server and try to manually update the DWF of a file (clicking "Update" from the Preview tab), immediately after clicking "Update" Vault returns an error message: "Unknown error during publishing" and no DWF is created.
Checking Windows Task Manager, when you try to update DWF on the Job Server, no additional task appears; when doing it on the client PC, the additional "Inventor Server For Vault" task appears during the DWF creation/update.
If I perform the same action from a client PC, the Update DWF works fine.
On the Job Server, Inventor is not installed, but it worked flawless without it (thanks to Inventor Server for Vault) on the latest release before the update (2019).
What can I check? There are a couple of Autodesk Knowledge Base documents about a similar error but they didn't solve the problem.
Thank you,
Regards
Matteo
