Drive Item revision from File based revision
brandon_stoner792L4
brandon_stoner792L4
There's alot of back story here, the question is simple. Can I create a customized item schema that would have the item's revision driven by the iPart/iAssembly factory file's revision in Vault?
I think this may be possible with customized categories and schemas but I wanted to ask.
@Andrew.Shaw
brandon_stoner792L4
Resolved by Irvin in similar post....not possible
File Revision to Item Revision - Autodesk Community
