Distributed Search Check-Out By User
gustavo.cassel
Message 1 of 10
gustavo.cassel
Hi, i'm trying to create a distributed search on vault to each user access their respective check-out files.
There is a way to implement that?
Like a "Check-out by" = "client-username"
Best regards,
Replies (9)
Message 2 of 10
Gabriel_Watson
Very important indeed, but unfortunately the best workaround now might be to save it as a parameterized search (prompting the user for value when triggered), I guess:
https://help.autodesk.com/view/VAULT/2024/ENU/?guid=GUID-0C7AA7BF-9158-4F8D-B312-CE0B2ED174A2
You should add this as an idea for us to vote and support it here:
https://forums.autodesk.com/t5/vault-ideas/idb-p/2
Message 3 of 10
Frederick_Law
I use this:
This will show all Checked Out files:
Message 4 of 10
gustavo.cassel
You do not get it.
I am the admin of the vault in my company, I want to create this search and share it as a distributed search to each user and see its respective checked out files.
Message 5 of 10
dave_taylor
There's no way to add a variable parameter inside of a search. Either you have to make several saved searches for each username or create a custom add-in to do this. I am working on something for our add-in to the Vault to do this very thing.
Dave Taylor
MCAD Solutions Engineer
Hagerman & Co.
Autodesk Certified Instructor - Platinum
*Likes to this post are appreciated if the information I have shared is helpful to you and/or others...
**Did this resolve your issue? Please accept it "As a Solution" so others may benefit from it.
Message 6 of 10
gandhey
Thank you for posting the idea @gustavo.cassel :
Distributed Search Check-Out By User - Autodesk Community
we have received this feedback and are going to look into this request.
Yogeshwar
(Vault team)
Message 7 of 10
ltYYCVK
What is the difference between My Searches and Distributed Searches in Vault?
When I save a search in the Find dialog it appears under My Searches. As seen in the image "Checked Out By ......"
How do I remove, modify or add folders under Distributed Searches?
Message 8 of 10
arkad_s
Autodesk Support
Autodesk Support
Distributed Searches can be maintained by Vault users with enough permissions (as these are distributed globally to all users):
Distributed Searches | Administration Enhancements (What's New in 2024.2)
Distributed Search | Vault 2024
If you don't see options to make/manage Distributed Searches, I guess you are not admin (so you do not have control over distributed searches).  You can maintain then only "My Searches" which are visible just for you, not for all users.
Arek
Arkadiusz Sukta
Sr. Technical Support Specialist
Customer Technical Success
Message 9 of 10
ltYYCVK
After I right click and press "Manage Saved Searches" I get this window. There is no option for me to create/make/manage any searches right?
So I guess, as you mentioned, I do not have admin rights.
Message 10 of 10
arkad_s
Autodesk Support
Autodesk Support
That looks like the case - using my test admin account I can turn on/off Distributed option for my searches:
And for you that option is greyed out.
You must contact your Vault admin then if you want to make some changes in Distributed Searches.
Arkadiusz Sukta
