Difference between link and attachment
I do not understand well the difference between a link and an attachment in the vault ?
I create an item and I would understand if I create a link or an attachment for pdf document.
Thank you. Regards,
Neil_Cross
When you say 'link' are you referring to files being shown in the items as primary and/or secondary associated files?
In simplest terms, a link is when a file controls the item and feeds property info to the Item.
An attachment is just when a file is attached, appended onto an item, it has no control over the item at all.
A full explanation of all the 'link' types can be found here:
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
