Delete Renamed Item with Lifecycles, Item Never Released / Used
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Vault Pro 2020
Long story short, sort of.
Issue,
We have been renaming our parts to follow a new format, I found a part that was renamed, along with the item.
For Example: Was "ABCD", now "1234".
I also need the previous number for a different part and it is now consumed by the item within the history. I don't know if this issue exists anywhere else in our system, but if it does and it becomes prevalent, I would like to fix it rather than work around it and assign another part number. That number "ABCD" is being used in other documents throughout the company as we prepare for a released version, there is no auto populate button on our end.
Actions,
I've tried purging all versions of item "1234" that are in WIP and Design Review. I don't believe lifecycle versions ever made it to "released" state. I [think] at least one version in a series prevents me from purging entirely, although the parameters for purging to - keep "first and last", have been now been updated to - keep "none", (temporarily). Though purge did not delete any other version.
Additional Observations
The "where used" tab has zero use of any version. (if they were used somewhere in the history I would understand the reason to protect this item). Thinking to self: If I delete this item, can I make a new item with the same name and reassign my "1234" part file to "new "1234" Item?
So, as a test run...
I created a new Item, named it something simple like - "Test-Item", so I could delete it and attempt to create a new item with the same name. Just to verify that I could potentially do the same with item "1234" with versions.
Currently, I can't delete either of them.
(yes, I attempted it, since the impact for this particular instance isn't that great.)
Role: Administrator
Group Administrator
All permissions granted (I made sure of it) "cue the insane laughter"
Side Note: (don't hang your hat on this bit of info, mentioning for clarity)
Could this be some sort of IT level protection outside of Vault? We are cloud based, no physical in house server.
Thank you in advance!
