Customer step files
I need to update my signature but we are on Inv 2015.
We receive step files for assemblies from some of our customers, and often they are similar to models they have previously manufactured so they reuse many of the parts. When we open the OEM step assembly and save it and then try to check it into Vault we get errors because most of the parts are already in Vault. From here it appears that our only options are to not save the assembly in Vault, rename the OEM parts so they will check in, or replace the parts with the OEM parts from Vault.
The parts that are reused may keep the same name, but we just had a case where the part was replaced and came in with a different orientation than the original part. Thankfully it was an obvious error (it came in upside down) but it may not always be. It is incredibly important to keep the original assembly intact because any dimensions not called out on the drawing are to come from their OEM model.
I very much need to find a workflow that is more efficient and more accurate than replacing all the customer files that are reused. If the solution is to simply not put them in Vault, that is worst case but may be what we have to do.
If you have a solution for this I would appreciate any help given.
Thank you.
