CREATING A SUBFOLDER IN INVENTOR 2024
rclement
rclement
I create a subfolder in window explorer. Then I start modeling .But when I try to save that file.
I dont see the folder I created. Is there a new way in 2024 to create a subfolder or is there a  limitation on how many subfolders you can create.I also you vault so that may also create problems
I created under inventor play a folder called crane hook but cant find it
CGBenner
@rclement
I moved this to the Vault forum, this appears to be Vault Data Standard.
Chris Benner
Frederick_Law
Vault will not see that folder until it's Check In.  It is a local folder.
If you're creating new file in Vault, create the folder in Vault.
