Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Copy Design won't work with released files.
b_ruijter
b_ruijter
In the video below you can see two atempts of copy design.
The copy design should copy a iam, ipn and a dwg containing the iam and ipn.
Both with the same files. Difference between the two is the state the original files are in.
First atempt the files are in "Work in progress" state. Second atempt the original files are releast. When the files are released the copy design gives an error. Is this a bug?
Richard.Rankin
Autodesk Support
Autodesk Support
Hi  @b_ruijter,
I followed the steps as per your movie and I could not reproduce the behaviour.
Is there already a file in your Vault called "165025.dwg"?
There have been a number of issues fixed for Copy Design in the updates. Did you apply the 2019.3.1 update?
If you find my response solves your question, please click the "Accept Solution" below the response
Richard Rankin
Vault Support Specialist
Global Product Support
Autodesk, Inc.
b_ruijter
Hello Richard,
Took me some time to do a follow up because we found a weird thing that you would not have beleived if i just wrote it to you. So i wanted to make the video of this avalable for you.
In short, no there is no drawing 165025.dwg already present & yes we have the latest update.
The weird thing we found, and it may contain a clue as where the bug may be found,  as you can see in the video below.
If we select the ipn and make a "copy to" of the ipn, and without any furter action switch back to "reuse" it looks as if we went back to the original state, but it actualy functions this time.
