Copy Design Issue with German OS
jlaidle1
jlaidle1
We're having an issue with 'Copy Design' with Vault installed on a German Operating System.  The links to AutoCAD xrefs are not being recognized.  Anyone else having this issue?
John Laidler
ITO - Application Management
Please use "Accept as Solution" & give "Kudos" if this response helped you.
rachel_li
Hello John,
Could you please let us know the Vault Product (Basic/Workgroup/Professional) and version are you using? And which product file(Inventor/AutoCAD/others) you are using contains links to AutoCAD xrefs?
Best Regards,
Rachel
Rachel Li
Software QA Engineer
Autodesk, Inc.
jlaidle1
AutoCAD 2016
Vault Professional 2016
John Laidler
Senthil_Kumar
i do not have Vault 2016/ACAD 2016 and i tested with 2019 combination. Please check the following Screen Cast. Copy design works for the ACAD files with XREFs. So could you please share some sample files for us? You can share here or send it to senthilDOTkumarATautodeskDOTcom
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
