Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Copy Design error Source file does not exist - temp file
madsAYQTQ
madsAYQTQ
I'm trying to use copy design but everytime i get the same error.
I'm told that a source file is missing and it refrences a temp file. I looked in the folder it refrences and can find the file myself so i know it exists.
Everytime i try it becomes new files it has problems with so it's not a consistant file with issues.
Have someone else experienced this and found a solutions.
Thanks for the help in advance.
CGBenner
@madsAYQTQ
Hello!  Can you show an image of your Project Explorer where the files are sitting before you try the Copy Design?  What folder were they checked into the Vault from?
Chris Benner
madsAYQTQ
@CGBenner
When i start the copy design i do it on this file:
Then in the copy design i then also copy a lot of the sub files.
Here they are not marked for copy because i just wanted to quickly find it, but they all get copied and sent to another folder:
I don't know if this is what you were asking for but i hope it can help in some way.
