compare cad files
compare cad files
compare cad files
Is it possible to compare two revision of one cad files(ipt,iam,step) in Autodesk Vault?
cbenner
@Anonymous
There is no specific tool set up for a side by side comparison, where it would show you the differences between the versions.  However, you can select a file in Project Explorer, go to the History tab, select a version and right click; "View in Window".  If you do this with multiple versions, you could place the view windows side by side and do a visual comparison.
