Check in error due to project file name
nimik23
Observer Observer
nimik23
Observer
Observer
I am need to check in the files I have been working on, and I am not allowed due to the project file having the same name? I haven't even checked the project file out. What can I do to check in the files?
CGBenner
@nimik23
Hello and welcome!  When you began the Check In, what did you select to be checked in?  Do you have any way of recording your workflow?
Chris Benner
ihayesjr
Can you show the check-in dialog before you get this error?
The Vault Browser doesn't indicate that the project file needs to be checked in.
Strange.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Gabriel_Watson
Refresh your project IPJ as per the article below if you're using Inventor ASI-Profile.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-The-followin...
nimik23
Observer
Observer
Thanks for the quick replies. I managed to fix it by logging off the Vault and logging back in. I assume it fixed the problem as it will have refreshed the project file as Gabriel_Watson suggested.
