Check in error after installing 2022
sbuckner6DW6H
Observer Observer
sbuckner6DW6H
Observer
Observer
Is anyone getting an error when trying to check in a drawing after installing 2022.
This is the error.
"A problem occurred while attempting to check-in [Filename].dwg' to [Path]. Would you like to continue checking any remaining files?
The Server returned the following information: Renaming failed due to an unknown error"
It will only do it when I have checked a drawing out of vault, make changes to it and try to check it back in. If I make a new drawing or change the name of the drawing everything works fine. All of the parts and assemblies check in as they are suppose to.
I don't know if this is an Inventor or Vault issue however we used our Vault 2022 for a week or two before upgrading our Inventor to 2022.
mcgyvr
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
mcgyvr
sbuckner6DW6H
Observer
Observer
Has there been any progress on finding a solution to this issue?
sweicikoskyLSD3T
Probably not.
Where I work, we now can't check in any large assemblies with dwgs.
Autodesk really screwed up.
