Hi @kpk7VYPK! I can sure try to help.
In this case, I think the original issue was that Vault was preventing an assembly from being changed to "released" because not all of the components used in it were already "released". In order to change this, you need to have sufficient admin access in order to alter the Lifecycle Definition that is causing you trouble.
Assuming you're using Vault 2024 Professional, you do have the required access to modify Lifecycle Definitions, you'll have to navigate to the appropriate "Transition" that is giving you trouble (ex: "Work in Progress" to "Released"), and edit it, then look for the "Actions" section and see what checkboxes are checked which mention checking for various things to be "released". See the snip below for an idea of what that section looks like.
Note that THIS WILL CHANGE IT FOR EVERYONE, not just you, so make sure that you won't get in trouble for making the changes.
You can get to this screen via the following steps from the main window.
- Tools Menu > Administration > Vault Settings > (Vault Settings Window Opens)
- Behaviors Tab > Lifecycles and Revisions Section > Lifecycles... > (Lifecycle Definitions Window Opens)
- Select desired Lifecycle 'X' to check/change > Edit Button (up top) > (Lifecycle Definition 'X' Window Opens)
- Select "Released" State in lower left > Transitions Tab (lower right) > "Work in Progress" to "Released" or other desired transition (Make sure the arrow is pointing towards "Released") > Edit Button > (Transition Window Opens)
- Select "Actions" Tab > Edit checkboxes as desired
