Change file names with upper case/lower case
Hi guys,
I'm already searched into forum and can't find a answer.
I need to change some characters in file name like, if file name is all in lower case, I need to change the first letter to upper case.
I can't rename because I use Enforce Unique File Names,  and I actually don't change the name, so Vault tells me that there are a file with this name, if I try to use Properties I can't change this thing too.
If I rename for another name and then change again, will create a new version of the file, and this is not good too.
If you guys know anything about that.
Thanks a lot!
gandhey
Interesting, but what you are looking for cannot be achieved using vault (unless you rename to some other name first).
Yogeshwar
(Vault team)
