Can the Job Processor create .STEP or .PDF files locally without saving to Vault
smorrisonNY464
smorrisonNY464
We are using the Job Processor to create .STEP files as needed (manually) and saving them to a network location and this works great. However, the Job Processor also creates a STEP file in the Vault every time. I see no way to stop the file creation within the Vault.
Is there a way to stop this or alternatively, an easy way to remove those files as soon as they are created?
Tony_Yates
go to vault setting and disable the option
OR USE THE DEFINE BUTTON
arkad_s
Autodesk Support
Autodesk Support
Hi  @smorrisonNY464
See this article for STEP files:
Is it possible to publish STEP files using Vault Job Processor from Inventor files into local drive ...
Same applies for PDFs
Kind Regards,
Arek
Arkadiusz Sukta
Sr. Technical Support Specialist
Customer Technical Success
smorrisonNY464
@arkad_s Thank you for the above link confirming: "In current design state there is no possibility to create STEP files using Vault Job Processor without adding file to Vault." as of December 2024.
ThomasRambach
That's not completely true. The Autodesk Vault Enterprise Tools are able to do this.
