Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Forum
Post 1 of 20
Accepted Solution
Can not access vault from within Inventor
1392 Views, 19 Replies
03-23-2012 07:33 AM
We recently upgraded from Inventor 2011 and vault 2011 to Inventor 2012 and Vault 2012. I am running 64 bit windows 7, I am not able to open from, save to, check in or check out from vault while in Inventor. I have no problems while in Autocad doing any vault commands. The vault add-in inside of Inventor is loaded. We have tried uninstalling Vault Client and reinstalling. Not sure what else to try.
I believe I have solved the issue. Its seems to be a registry error. Thank you for your help.
Re: Can not access vault from within Inventor
03-23-2012 07:43 AM in reply to: ro01
ro01,
Let's start with the obvious, do you have a Vault tab on the Inventor ribbon menu?
If so, is only the "log in" icon highlighted?
If yes, you need to log into Vault from within Inventor. Then make sure you have the correct project selected and active.
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
Post 3 of 20
03-23-2012 07:44 AM in reply to: ro01
Do you have a Vault ipj active? If you have a non-Vault ipj active, the Vault commands are not available.
Adam
Adam Luttenbacher
Sr User Experience Designer
Autodesk, Inc.
Post 4 of 20
03-23-2012 07:58 AM in reply to: CelticDesignServices
I should have said that. Yes my project file is set to the vault project, and I am loged into vault inside of Inventor, and the connection status says I am connected.
Post 5 of 20
03-23-2012 08:06 AM in reply to: ro01
Also the "Go to Vault" and "Log Out" buttons are the only buttons not greyed out on the Vault tab.
Post 6 of 20
03-23-2012 09:10 AM in reply to: ro01
That's interesting. All of your symptoms point to having a non-Vault project file active in your project editor. If you don't have a Vault add-in active, you can still see the Vault buttons but they are all grayed out.
If you want, showing a screen capture of your project editor might help confirm.
Adam
Adam Luttenbacher
Autodesk, Inc.
Post 7 of 20
03-23-2012 09:24 AM in reply to: luttena
Here is a group of screen shots showing the active project, the vault controls locked out, and what add-ins are active in Inventor. Thanks for the help
Post 8 of 20
03-23-2012 09:30 AM in reply to: ro01
My workspace is set to the X:\work because our computers are setup to have the local drive with the operating system on it frozen. The X: drive is a local partition that is not frozen.
Post 9 of 20
03-26-2012 08:15 AM in reply to: ro01
Thanks for the clarification. Have you mapped the project file to Vault folders yet?
Adam
Adam Luttenbacher
Autodesk, Inc.
Post 10 of 20
03-27-2012 07:25 AM in reply to: luttena
I am not sure what you mean. The project file was mapped when it was autoloaded into the vault last year. Do I need to remap it after upgrading?
Post 11 of 20
03-27-2012 08:58 AM in reply to: ro01
Nope. That should be fine.
Adam Luttenbacher
Autodesk, Inc.
Post 12 of 20
03-27-2012 01:59 PM in reply to: luttena
Post 13 of 20
11-05-2012 10:44 PM in reply to: luttena
Hi There
I have this same issue and I was wondering what were the steps that you took to correct your resgistry error?
Tarryn
Post 14 of 20
11-06-2012 05:23 AM in reply to: luttena
I am sorry I don't remember the exact process, our Autodesk Vendor assisted us. I believe we deleted the Inventor and Vault directories out of the registry and let the applications rebuild the registry. I don't remember if there was another step.
Good luck
Post 15 of 20
11-06-2012 05:50 AM in reply to: ro01
Thank you very much for the reply.
Tarryn
Post 16 of 20
03-01-2013 05:55 AM in reply to: tarrynd
I'm having the same issue.
All addins are loaded, even the hidden EDM and I have the Vault project file active.
Does anyone knows which registry keys must be adjusted /deleted?
Danny van Duijn
Post 17 of 20
04-30-2013 04:59 AM in reply to: DannyVanDuijn
 Danny,
I have just ran into the same problem. Did you resolve this? How did you do it?
Thanks for some help.
Douglas DuPont
Inventor 2016 Pro, Vault 2016 Pro
Quadro M4000
Windows 10 64 Bit
Post 18 of 20
04-30-2013 06:09 AM in reply to: luttena
I believe what we did was delete the Inventor folder from the HKEY_CURRENT_USER\Software\Autodesk in the registry. Then when you start Inventor it will rebuild the registry correctly so it can communicate with Vault. Unfortunately this will remove any custom settings you may have done in Inventor. Remember to backup the the Inventor directory before you delete it just incase you are deleting the wrong folder.
Good Luck
Post 19 of 20
05-02-2013 04:26 AM in reply to: ro01
I found my problem,
In Inventor I when to the Addin's Panel, Right clicked and "Show Hidden Menbers"
The EDM Addin needed to be restarted.
Now Why this is a Hidden Addin I don't know? It is the only 1 that is Hidden?
Douglas DuPont
Quadro M4000
Windows 10 64 Bit
Post 20 of 20
05-05-2013 02:28 AM in reply to: Doug_DuPont
Hi Doug,
I did not solve it. The workstation was reinstalled (including OS) to solve several (performance) problems.
Of course this issue was resolved after the reinstall.
Danny
Post to the Community
New Post
