Hi. Have you got an idea about this problem. I use the batch plotting of vault 2012, when I wan't to print dwg files, I've got a error : "The file was created with Autocad application. This application was not found on your computer". This message arrive only with dwg files. I can plot ipt, or iam with no problem. What can i do?
Is Autodesk TrueView installed on your machine? If not please try to install it and then try batch plotting again.
-Hywell
There is a known issue about the error on X64 system operation.
If your status isthe same issue, please try to install Omaha SP1 to solve it.
Carrie
