AutodeskDM virtual directory found on your website Default website
I'm having some problems re-installing Autodesk Vault Basic Server 2020.  I am getting the pre-check error:
"AutodeskDM virtual directory found on your website Default website"
I have tried:
  • 'repair' and full re-install of vault.  Same error.
  • Full uninstall and of IIS and Vault and then re-install of IIS then Vault. Same error.
  • On the re-installed IIS I have checked that there's no Default Web Site>AutodeskDM virtual folder in the IIS Console before re-installing.  Also there isn't a physical folder C:\Program Files\Autodesk\ADMS 2020\Server\Web. Same error.
  • I've installed Vault 2020 on a similar fresh machine and it works fine. (unfortunately I can't use this machine for production)
Can someone please tell me what is still lurking in there that makes the installer think that the AutodeskDM virtual directory still exists?
Thank you.
oleksandr.herus
@Anonymous  Have you tried steps described over here: https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Vault-Install/files/GUID-C0952BE1-B6F6-48DD-90EB-F88B00FFE728-htm.html ?
Oleksandr Herus
Senior Software Engineer
Autodesk, Inc.
oleksandr.herus
I already see that you don't have Autodesk DM virtual directory in your IIS console, please disregard.
Oleksandr Herus
Autodesk, Inc.
Hi Alex, yes. as you say, I can confirm that there are no AutodeskDM virtual folders in IIS.
I ended up rebuilding the OS on this machine to fix the issue.  (A bit drastic I know).  This (obviously) did the trick of removing whatever the installer thought was there allowing it to proceed.
