Autodesk.Connectivity.Webservices.Interop error with App from AU2016
JacksonBrent
JacksonBrent
I took a vault reporting class at AU2016 and they gave us an app that will automatically do advanced searches in the Vault and save the results in a spreadsheet.  It's a bit involved to set up, but I have it almost working, when I go to log in I get this error though 😞
Here is the program if anyone is interested in trying it out for themselves.  I'm going to use it with power BI to monitor vault usage.
InvalidServer:  Could not load file or assembly 'Autodesk.Connectivity.WebServices.Interop, Version=22.0.0.0, Culture=neutral, PublicKeyToken=aa20f34aedd220e1' or one of its dependencies. An attempt was made to load a program with an incorrect format.
I can post more info about this if anyone is interested in helping, but don't want to bog the question down with a bunch of text that isn't necessary.
Thanks!
Brent
tim.bourdois
Hi Brent...
Thanks for participating in the class at AU this year.  We certainly appreciate your presence and interest.  I guess this is the "your mileage may vary" part in the disclaimer about the tool.  That said, I'll try to connect with Dean about this after the holiday to see if we can give you any clues as to what may be happening.
Don't be shy about following up here.
Happy Holidays and thanks again for attending AU 2016
Tim
PS... any additional information you can provide about your experience and environment would definitely be helpful (OS, Service packs, Vault Version, etc.)
