Whenever I check in new files (such as inventor models and drawings), I have rules set up so that they are automatically put into the right categories, and therefore the correct revision schemes and lifecycles. However, whenever I check in any new file, Vault always puts it under the "default" category that is set. Why aren't the files being put under the categories they should be going to automatically from the rules that were set?
Solved by gandhey. Go to Solution.
Please check if you have the checkbox 'Apply Rules on Object Creation' checked/marked in the 'Rule' dialog?
Also check if you have same rule condition for different rules you may have, in such case the rule precedence will govern the rule assignment.
Yogeshwar
(Vault team)
I did check to see if it is checked marked, which it is as you can see in the attached snips. Also, I attached snips of each rule and the criteria. I don't believe it is the same but if you think it is, please let me know what should be done. Notice that the default rule is also set to a random category I picked (I am not sure if this also affects anything or not). There is no rule criteria set for the default rule.
Please let me know! Thank you!
Please note that the Rule Conditions follow an AND condition. (not OR)
You may use some of the suggestions here to build the rules :
https://underthehood-autodesk.typepad.com/blog/2010/03/category-assignment-cheat-sheet.html
Yogeshwar
(Vault team)
I understand. I originally thought it was based on an OR basis. I just fixed my rules and now they are working. Thank you very much!
