Have an issue with Vault Basic server 2018 where after a Windows Server 2012 R2 update, users could not connect to the Vault. I've been through all the help on the url given, however none of the solutions work.
After Googling this issue, it appears NET Framework 4.7 could be the culprit. I uninstalled KB3186539 update, however that did not solve the problem.
I have since restored the server from an image before the Windows update to get back up and running, however, I know the update will just be installed again.
I even tried to uninstall Vault 2018 and replace it with Vault 2019 (where I see it installs NET Framework 4.7 from the Autodesk install media), however I received the same error message in the installation pre-checks, and received the same url help page where none of the solutions worked.
Has anyone else run into this issue, and do you have a solution?
