API: Change Lifecycle State
Does anyone have an example of how to change a file from one lifecycle state to another, e.g. 'released' to 'work in progress'?  Also, how do you deal with the Document Service Extension, is there a security header?
-Pete-
Redmond.D
DocumentServiceExtensions.UpdateFileLifeCycleStates is the function you want to use.  The Recycle Bin 2.0 uses this function and has some sample code you can look at.
Yes, you have to deal with the SecurityHeader for DocumentServiceExtensions.  The process is the same as same as with the DocumentService, you log in then you copy the SecurityHeader information over from the SecurityService.  This is demonstrated in a video.
Doug Redmond
Software Engineer
Autodesk, Inc.
OK, that worked, thanks.
