Access 2015 Vault through VBA
I'm starting a project to access a 2015 Vault using VBA which will most likely run in MS Excel.  Can some point me to some sample VBA code that initiates the connection?
Thanks, Bob
iancross
Hi Bob
your best posting in the Vault customisation forum, but also have a look at just ones and zeros webpage http://justonesandzeros.typepad.com/ , There is some good sample codes there to get you started
There is also tuorials and samples on the Autodesk ADN siet http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13433205
Ian Cross
www.xcrosstech.com
Vault, Inventor, and MFG Specialist
Across Technology, Across Industry
