Hi all,
I've been searching for the past couple days to no avail. Hopefully someone here might have some ideas because I'm all out!
Basically, I'm able to log in to vault through the stand-alone Vault Basic 2016, but when I try to log in through inventor I get "Inventor 2016 Vault Addin could not find the Data Management Services on [server IP]."
Other users on the network are able to log in through Inventor with no issues.
Specs: Design Suite Premium on Windows 10 with ADMS 2016 installed on Windows Server 2012 Standard.
Attempted solutions so far:
Server Log anomalies, unsure if relevant:
Event Processing: The configured event handler failed to load: Autodesk.ECO.EmailNotification
Exception: Could not load file or assembly 'Connectivity.ProductStream' or one of its dependencies. The system cannot find the file specified.
10/26/2015 6:30:52 PM *******************************************************************
Event Processing: The configured event handler failed to load: Autodesk.Item.Purge
Event Processing: The configured event handler failed to load: Autodesk.Lock.Vacuum
