Where to deploy Xceed.Wpf.Toolkit.dll
ifrankel
ifrankel
I'm customizing the Data Standard dialog box located in C:\ProgramData\Autodesk\Vault 2018\Extensions\DataStandard\CAD\Configuration\AutoCAD.xaml. I need to implement a textbox edit mask so I installed the Extended.Wpf.Toolkit into the project I have open while modifying and testing the form. I added the MaskedTextBox to the form and it displays fine in both VS 2017 and in Blend 2017. However, once I ran AutoCAD Civil3D and brought up the Data Standard dialog box, I got the following error message:
    Cannot create unknown type '{http://schemas.xceed.com/wpf/xaml/toolkit/}MaskedTextBox.
I've tried deploying the dll to the following folders without any success:
  -- C:\ProgramData\Autodesk\Vault 2018\Extensions\DataStandard
  -- C:\ProgramData\Autodesk\ApplicationPlugins\Autodesk DataStandard 2018.bundle\Contents
  -- C:\Program Files\Autodesk\Vault Professional 2018\Explorer
  -- C:\Program Files\Autodesk\AutoCAD 2018
Here's my declaration at the head of the xaml file:
xmlns:xctk="http://schemas.xceed.com/wpf/xaml/toolkit"
Am I wrong to assume this can be done in the AutoCAD.xaml environment?
wangdu
If you are just placing the Xceed.Wpf.Toolkit.dll in one of those folders, it would not load. You need to call either Add-Type Cmdlet or using reflection Assembly LoadFrom() depending on the powershell version to load the assembly.
Hope it helps!
Wangdu
coolOrange
www.coolOrange.com
ifrankel
Adding the dll name and location into Default.ps1 via the following statement worked perfectly:
[System.Reflection.Assembly]::LoadFrom("C:\Users\ifrankel\Documents\VSTS\Product\Source\Vault.DataStandard.Custom\bin\Debug\Xceed.Wpf.Toolkit.dll").
Thanks!
