Vault Pro 2024 API Error
o-fischer
o-fischer
We try to upgrade all internal developments with Autodesk vault pro 2024 SDK dlls. There is some new dlls:
AdskIdentitySDK.dll
AdskLicensingSDK_7.dll (this one was existing in version 6 for Vault Pro 2023)
Autodesk.Connectivity.IDServicesWrapper.dll
When we replace and add those dlls into our project, we have the following error:
See our new environment:
We just saw, the Autodesk.Connectivity.IDServicesWrapper.dll is version 27, not 29 like all others.
Thanks for your help.
Sandybxs
I am running the same issue related to "Autodesk.Connectivity.IDServicesWrapper.dll" when upgrade the code from 2020 to 2024.Any ideas? thanks
zongbo_li
Hi Sandybxs,
Have you place the AdskIdentitySDK.dll in place? You may also want to user ProcessMonitor to see what dll is your application is looking up.
o-fischer
   Yes AdskLicensingSDK_7.dll is also published. I will try to see if I can use ProcessMonitor.
Olivier
davide_confortiYDK9M
Community Visitor
Community Visitor
We've got the same issue... Any advice on this?
