Vault Pro 2018: Item Thumbnail update
o-fischer
o-fischer
     I tried to update Thumbnail property for an Item and i get an error 3933. Is it possible to update this property if it's a System property?
This is what i tried:
VDF.Vault.Currency.Properties.ThumbnailInfo thumbnailInfo = new VDF.Vault.Currency.Properties.ThumbnailInfo(VDF.Vault.Currency.Properties.ThumbnailInfo.ThumbnailType.Thumbnail, System.IO.File.ReadAllBytes(selectedFile));
PropDef[] AllProperties = m_serviceManager.PropertyService.GetPropertyDefinitionsByEntityClassId(VDF.Vault.Currency.Entities.EntityClassIds.Items);
PropDef thumbnailPropDef = AllProperties.FirstOrDefault(x => x.DispName == VDF.Vault.Currency.Properties.PropertyDefinitionIds.Server.ThumbnailSystem);
PropInst[] PartThumbnailPropInt = connection.WebServiceManager.PropertyService.GetProperties(VDF.Vault.Currency.Entities.EntityClassIds.Items, new long[] { part.Id }, new long[] { thumbnailPropDef.Id });
List<PropInstParam> propinstparams = new List<PropInstParam>()
new PropInstParam(){Val = thumbnailInfo.Image, PropDefId = thumbnailPropDef.Id }
var myPropInstParamArray = new PropInstParamArray() { Items = propinstparams.ToArray()};
List<long> editItemids = new List<long>();
try
Item[] editableItems = m_serviceManager.ItemService.EditItems(new long[] { part.RevId});
editItemids = editableItems.Select(x => x.Id).ToList();
long[] _masterIds = editableItems.Select(x => x.RevId).ToArray();
Item[] updatedItems = connection.WebServiceManager.ItemService.UpdateItemProperties(_masterIds, new PropInstParamArray[] { myPropInstParamArray });
connection.WebServiceManager.ItemService.UpdateAndCommitItems(updatedItems);
catch (Exception)
connection.WebServiceManager.ItemService.UndoEditItems(editItemids.ToArray());
Olivier.
psaarloos
Hi Olivier,
Does it fail on this line?
If so, I think you're right. Because it's a system property it fails. I know you can create a UDP and define the type as 'Image' by using the API (not possible through UI). You could store your own thumbnail in there. Don't know if it solves your problem, but it might be good to know 🙂
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
