Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Vault DataStandards Filename and location from properties
1 REPLY 1
richardbron
250 Views, 1 Reply
I want to create new files from Vault. I created a xml file with dependencies. If in the first option 1 is selected then the second option is different then when 2 is selected. That part works. Also the name should be generated depending on the choices looking something like this:
  • Design Type
  • MainGroup (Predifined)
  • SubGroup (Predifined but depended on MainGroup choice)
  • Project
  • DrawingNumber
The filename should be MainGoupSubGroup-Project-DrawingNumber.ipt
The location should be Design Type\MainGroup\SubGroup\ProjectNumber
Can this be done with the Vault DataStandards?
1 REPLY 1
Nick_Hall
in reply to: richardbron
Hi Richard
Yes,it can. You will need to create some code that runs every time one of the components of the file name changes and generates the file name.
Then you can set the returned filename using a line like this, where $fileName is your generated file name
$Prop["_FileName"].Value = $fileName
That gets passed back to the VDS code, which will create your file from the selected template.
Hope that helps
Nick
