SQL SELECT Query
SQL SELECT Query
xavier_dumont2
SQL SELECT Query
xavier_dumont2
The original official statement from Autodesk is: All SQL access is prohibited.
But today I found a new post and I ask you (an Autodesk employee) to clarify the situation.
This one explain it's prohibited to access directly the SQL database. But in the samples, nothing about SELECT queries. => SELECT prohibited YES or NO?
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
This one explain that Autodesk Support don't provide SQL Query and you need to create it by yourself.
Then it's allowed to do a SQL query?
Thanks in advance to clarify this.
ihayesjr
It is not allowed to perform any operations that directly access the Vault databases. You must use the APIs to perform the needed operations.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
