The readme says --
Please make sure AdSSOServices.dll is in search path so the web app can load it. You can update the
system environment PATH to include the path to Autodesk Vault 2022 SDK\bin\x64, or copy the dll to
existing path location, e.g., C:\Windows\. If the dll can't be found in PATH, you may see
"Could not load file or assembly" error for 'Autodesk.Connectivity.AdSSOWrapper' on the web page
when run the sample.
Does that mean I need to install 2022 SDK? I cannot find AdSSOServices.dll in 2024 SDK.
Solved by gang. Go to Solution.
You should be able to find the reference needed in the "C:\Program Files\Autodesk\AdskIdentityManager\Current" folder or similar on your machine if 2024 is installed.
thanks
Mike W.
Well, the instruction for this sample provided in Autodesk SDK 2024 is not correct. I contacted ADN support and the assembly file group should be AdskIdentitySDK.dll and AdskIdentitySDK.config, not AdSSOServices.dll.
