Hello
We have a new little problem here.
On some clients, the Data Standard frame generator will not open in Inventor. It shows only the original Inventor frame generator dialog.
We are using Inventor 2017 SP1 Build 196 with Data Standard 2017.0.1
The PC's are all different (Win 7; Win 10)
All clients have the same config.
Install / Uninstall I've already tried.
There's no error in the Data Standard logs.
Is there a known issue?
Have you by the way tried both DataStandard 2017 and DataStandard 2017 Update 1.
Give it a try. Hope it helps!
Wangdu
coolOrange
