Powershell to get Vault Change Order ID #?
ThomasRambach
ThomasRambach
I need to get the vault change order id number for input on a few change orders that we imported into Fusion Lifecycle before our integration tool was ready. Does anyone have a quick and easy powershell script to get the change order ids?
Replies (11)
sajith_subramanian
Autodesk Support
Autodesk Support
Hi @ThomasRambach,
If I understand your requirement correctly, you want to fetch the Change order Id's for your given Change order numbers?
I am not an expert on powershell, but take a look at the below script that does something similar
Add-Type -Path ("C:\Program Files (x86)\Autodesk\Autodesk Vault 2018 SDK\bin\x64\Autodesk.Connectivity.WebServices.dll")
$serverID = New-Object Autodesk.Connectivity.WebServices.ServerIdentities
$serverID.DataServer = "myServerName"
$serverID.FileServer = "myServerName"
$VaultName = "MyVault"
$UserName = "Administrator"
$password = ""
$cred = New-Object Autodesk.Connectivity.WebServicesTools.UserPasswordCredentials($serverID, $VaultName, $UserName, $password)
$vault = New-Object Autodesk.Connectivity.WebServicesTools.WebServiceManager($cred)
$co = $vault.ChangeOrderService.GetChangeOrderByNumber("ECO-000020") # input eco number here
$co.Id  #required id number
$vault.Dispose()
Hope this helps.
Sajith
Sajith Subramanian
Autodesk Developer Network
ThomasRambach
That worked absolutely perfectly. Thank you.
J_Dumont
I'm using powershell and i wonder if it would it be possible to get the change order number of a file of its controlled by a change order?
Markus.Koechl
You can get it using ChangeOrderService.GetChangeOrderFilesByFileMasterId. The extended sample configuration VDS-PDMC-Sample implemented it as part of the Revision tab:
	#copy number if ECO drives the revision
	$mFile = mGetVaultFile
	$mEcoFile = $vault.ChangeOrderService.GetChangeOrderFilesByFileMasterId($mFile.MasterId)
	if ($null -ne $mEcoFile) {
		$mEcoNum = $mEcoFile[0].ChangeOrder.Num
		$Prop["Change Descr"].Value = $mEcoNum
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
J_Dumont
Hi Markus,
That worked perfectly!! Thank you.
If I could impose just a bit more.
Now that I have the ECO Number, I would like to update a Property with it.
I've tried using the UpdateFileProperties but I'm having issues with the syntax.
Markus.Koechl
Likely, you struggle to build the dictionary. There are solved samples around: Solved: Re: UpdateFileProperties Error in 2017 - Autodesk Community - Vault
Or my GitHub samples: iLogic-Vault/iLogic-Vault-QuickstartLibrary/iLogic-Vault QuickstartLibrary.cs at 2023.3 · koechlm/iL...
Markus Koechl
J_Dumont
Thanks for the info but I see the information is in C+ and I'm not sure how to code this in Powershell.
This is what I have so far but I'm getting an error in the last line as shown below.
Exception calling "UpdateFileProperties" with "2" argument(s): "1136"
$FileMID=$file.MasterID
$mEcoFile = $vault.ChangeOrderService.GetChangeOrderFilesByFileMasterId($FileMID)
$unmappedPropertyName = "Cost"
$propDefs = $vault.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE")
$myProperty = $propDefs | Where-Object {$_.DispName -eq $unmappedPropertyName }
$propInstParamArray = New-Object Autodesk.Connectivity.WebServices.PropInstParamArray
$propInstParamArray.Items += New-Object Autodesk.Connectivity.WebServices.PropInstParam -Property @{PropDefId = $myProperty.Id; Val = $mEcoNum }
$updatedFile = $vault.DocumentService.UpdateFileProperties(@($FileMID), @($propInstParamArray))
Markus.Koechl
You aren't using VDS, right? If so, I guess you also expect the property written in the file. I found a sample in Powershell in my older treasures that I did not touch for years ;): VDS-Sample-Configurations-2024/VDS-PDMC-Sample/Vault.Custom/addinVault/Menus/ADSK.QS.AdskFilePropPro...
Markus Koechl
J_Dumont
No, not using VDS.
I failed to mention that I'm using PowerShell with coolOrnage powerJobs and they have an object that I was able to get to work.
$updateProp = Update-VaultFile -File $file.'Full Path' -Properties @{'Subject'=$mEcoNum}
Thank you for your support!!!
Tony_Yates
Hi J Dumont,
This sounds like something we could use. We are using cool orange. Would you be kind enough to share your code?
Tony
J_Dumont
Hi Tony,
I created a custom UDP in Vault called, ECO_Number and then assigned this in the Vault Revision Table Settings as shown below.
Here is the code I use in a powerEvents script.
$mEcoFile = $vault.ChangeOrderService.GetChangeOrderFilesByFileMasterId($file.MasterID)
Update-VaultFile -File $file._FullPath -Properties @{'ECO_Number'=$mEcoNum}
FYI..I'm hosting a webinar showing many of the Automation procedures I created with powerJobs and powerEvents and you are welcome to attend. It takes place on 12/14 at 1 pm EST.
The registration for the webinar is https://microcad3d.com/#events
