Map filename from PDF-file to file-object UFP
tpaaYFMZT
Message 1 of 1
tpaaYFMZT
When I drag a PDF file into the Vault, a file object is created and some properties are mapped to system properties.
Is it possible also to map the filename to a User Defined Property? The PDF provider seems to provide things like file size, but filename is not one of them...?
Replies (0)
