Library.ConnectionManager.LogIn Issue
ThomasRambach
Advisor Advisor
ThomasRambach
I'm not sure why this code doesn't work:
string VaultServerName = "VaultServer"
string VaultDatabase = "VaultDatabase"
LogInResult logInResult = Library.ConnectionManager.LogIn(VaultServerName, VaultDatabase, "Administrator","Password", AuthenticationFlags.Standard, null);
But this code does:
LogInResult logInResult = Library.ConnectionManager.LogIn("VaultServer", "VaultDatabase", "Administrator","Password", AuthenticationFlags.Standard, null);
Error:
{"The type initializer for 'Autodesk.Connectivity.WebServicesTools.WebServiceManager' threw an exception."}
Doesn't make sense why that line doesn't except anything but the entry manually included?
sajith_subramanian
Autodesk Support
Autodesk Support
Hi @ThomasRambach,
I could not reproduce the error that you have mentioned. The below code seems to work well for me:
string VaultServerName = "localhost";
string VaultDatabase = "TestVault";
LogInResult logInResult = VDF.Vault.Library.ConnectionManager.LogIn(VaultServerName, VaultDatabase, "Administrator", "", AuthenticationFlags.Standard, null);
Sajith
Sajith Subramanian
Autodesk Developer Network
I'm getting the same error when I try to call this method from a .NET Core 2.1 Entity Framework project and Vault 2017 dlls.
Is this an issue related to missing references?
sajith_subramanian
Autodesk Support
Autodesk Support
Can you check out the solution in the below link:
https://forums.autodesk.com/t5/vault-customization/error-while-trying-to-login-to-vault-through-api/...
Let me know if it works for you.
Sajith
Sajith Subramanian
