Issue on running the HelloWorld program
wingfaimanJN5SK
wingfaimanJN5SK
Dear ,
I try to run the program under
C:\Program Files\Autodesk\Autodesk Vault 2022 SDK\VS19\CSharp\HelloWorld
by using Microsoft Visual Studio 2019
When I try to Build>Rebuild Solution, the error shown:
C:\Program Files\Autodesk\Autodesk Vault 2022 SDK\VS19\CSharp\HelloWorld\HelloWorld\HelloWorldCommandExtension.cs(32,12,32,20): error CS0246: The type or namespace name 'Autodesk' could not be found (are you missing a using directive or an assembly reference?)
wingfaimanJN5SK
Hi, Any one can tell me ? thanks
Boorda
I'm not sure that you've provided enough information for anyone to be able to guide you.
  • Do you have multiple versions of Vault installed on your machine?
  • Are you referencing the correct versions of the Autodesk assemblies?
Automation is key!
wingfaimanJN5SK
Hi Boorda,
Vault Professional 2020, 2021, 2022
Runtime Version (v4.0.30319, please see attached)
Markus.Koechl
Vault 2022 expects a target framework of 4.7 or higher. The warnings before the error message returned this info.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
wingfaimanJN5SK
thanks
